It is currently Thu Feb 22, 2018 2:04 am
Post new topic Reply to topic  [ 13 posts ]
Author Message
PostPosted: Mon Feb 22, 2016 10:42 am
Offline
I was just wondering how often everyone changes their brake fluid and radiator coolant. The manual says to replace the radiator coolant every 24000 miles or 2 years, whichever comes first. And to replace the brake fluid every 12000 miles or 2 years, whichever comes first. Is is necessary to change them every 2 years if we are not close on the miles?
Top
 Profile
PostPosted: Mon Feb 22, 2016 11:55 am
Offline
Year: SV650AL7
Color: The correct one
Yes.
Both should be changed at the specified interval for optimum performance.
But they will still work reasonably OK if you don't change them.
Coolant has corrosion inhibitors and these stop working as time goes on.
Brake fluid absorbs moisture and this reduces its efficiency.
ABS pumps can be susceptible to damage from old brake fluid, given the price of an ABS pump its maybe worth changing fluid if you have an ABS model.
However, imo its only worth changing the coolant and brake fluid if you intend keeping the scooter for a while.
If you plan to sell after three or four years why bother?
_________________
Top
 Profile
PostPosted: Fri May 19, 2017 3:10 am
Offline
Year: Forza300 2014
Color: Silver grey
reviving an old post....due to try change the coolant on my Forza 300... 2.25 yrs and 12000 mls.....reading the manual I am slightly concerned that getting all the old coollant out may be a problem. Any comment on issues should I not get all the old coolant out? If new coolant is say 90% of the total coolant is that a problem ...or OK/acceptable if not perfect?
thanks....and apologies if this reads as a daft question....better safe than sorry.
Top
 Profile
PostPosted: Fri May 19, 2017 5:50 am
Offline
Color: blk
Gn 2 response is accurate, however given the simplicity and inexpensive cost it is reasonable to change more frequently. I use a once a year interval regardless of miles but like Gn2 says it is probably not necessary as these chemicals are fairly long lasting. No it is not a big deal to leave in some old antifreeze, but you shouldn't have to.Any residual fluid will integrate just fine with the new stuff if its the same specification .Make sure replacement fluid is compatible with aluminum as most good brands are.( No need to specify HONDA brand )
Top
 Profile
PostPosted: Fri May 19, 2017 7:44 am
Offline
Year: Forza 300
Color: red/2014
Getting 100% of the coolant out requires disconnecting the lower rad hose from the pump,
I found. Then giggling the scooter left and right helps (the shop manual procedure is more elaborate, but this short-cut works). Then it is very important to properly bleed the system upon refilling (the bleed bolt is -barely- accessible through a luggage box trap door).
Not a job for the mechanically challenged, even if it looks 'easy' at first glance (manual says 'requires skills').
Same applies to the brake fluid replacement. Very easy apparently, but also very easy to end with a mess.
Top
 Profile
PostPosted: Fri May 19, 2017 9:33 am
Offline
Color: blk
That's the same way I did it. I think I did suck out the reservoir with a large syringe type pump , then opened the radiator cap then removed the botton rad hose to drain. I personally found this to require elementary skills and only needed a pliars and I think a 10 mm open end wrench for the bleed screw. Removing the lower panel was easy too and only required a 10 mm socket if memory serves me.
Bleeding the brakes can be messy but not if you take simple precautions Ie catch can , rag, and syringe. I would go for it and it will give you a sense of accomplishment and save 100.00 to boot.. ??
Top
 Profile
PostPosted: Fri May 19, 2017 9:44 am
Offline
Year: Forza300 2014
Color: Silver grey
Thanks for the constructive comments. Was at Honda dealer in Glasgow today...
Forza in for the last recall work....
and got some ready made Honda coolant..so will give it a go...mechanic I spoke to said advisable to get all coolant out but not essential. Got the impression that they don't get it all out!
Changed the brake fluid 6 months ago myself and didn't find that over difficult.
Top
 Profile
PostPosted: Fri May 19, 2017 9:48 am
Offline
Coolant hit the low mark at 5k for my new PCX, that took me less than two years accomplish. Don't know about Forza engine but at the very least check and top off the coolant for sure.
_________________
PCX Whisperers: maddiedog- dem0nk1d- waspmike- dasshreddar- GN- sendler2112- honkerman- DAB- BPT7594- Oyabun- silverantec- chicaboo- ThailandPCX- Dragon_uk- TrumpMAGA- k2apache6.0- pcx power-full- JaeMelo- markgj- Techno
Top
 Profile
PostPosted: Fri May 19, 2017 11:18 am
Offline
Color: blk
Here is a method that I developed for flushing the brake fluid. Now, my method albeit a little elaborate but all you have to do is open caliper bleeder let it gravity feed into a catch can. Make sure the master does not go empty.. and never pump the brakes..just let it drain for awhile..
https://1drv.ms/v/s!AvV-j2ZMUDvrnn_6VsSuWQmwIgvq
Top
 Profile
PostPosted: Fri Jun 09, 2017 12:45 am
Offline
Year: 2015 NSS300A
easyrider: Link doesn't work for me. Can you post on youtube?
_________________
Salsbury
Top
 Profile
PostPosted: Fri Jun 09, 2017 6:46 am
Offline
Color: blk
yes..here it is
https://youtu.be/uLyHv6C7TEA
Top
 Profile
PostPosted: Fri Jun 09, 2017 12:41 pm
Offline
Location: Lying in the gutter in the centre of the universe
Antifreeze. It'll just be fine as long as it's topped up to the correct levels and the temperatures aren't at either end of the spectrum extreme.
Brake fluid will be fine too. If it gets dark, not discoloured then change it straightaway. If you maintain your bike regularly. Then an easy thing to do is use a syringe to change the master cylinder fluid. Change it again when it gets discoloured. This will have the QWERTY mechanics springing to the keyboard but it works in the real world.
_________________
Flu based abstinence
Top
 Profile
PostPosted: Fri Jun 09, 2017 1:54 pm
Offline
Year: Forza 300
Color: red/2014
Yes, syringe is the way. First, to empty the master cyl., then to push back new fluid through
the caliper's bleed bolt...and repeat till the fluid in the master looks 'good'. I go slooow,
cuz paint HATES brake fluid...
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
