Page 1 of 2
Mirrors
Posted: Wed Sep 06, 2017 2:12 pm
by The Poacher
Hi, can anyone recommend me some slightly wider mirrors, I'm quite broad shouldered and I'm struggling to see behind me clearly.
Re: Mirrors
Posted: Wed Sep 06, 2017 2:19 pm
by default
Re: Mirrors
Posted: Wed Sep 06, 2017 2:30 pm
by The Poacher
Haha, not quite big enough!!
Re: Mirrors
Posted: Wed Sep 06, 2017 4:03 pm
by Jge64
Get the same mirrors from Honda, except they're wider ...I believe they are for the CB500X…
Re: Mirrors
Posted: Wed Sep 06, 2017 4:06 pm
Jge64 wrote:Get the same mirrors from Honda, except they're wider ...I believe they are for the CB500X…
Can anyone confirm this. I'd like to have wider mirrors to but retain the OEM look.
Re: Mirrors
Posted: Wed Sep 06, 2017 5:09 pm
by Jge64
So you don't believe me?
LOL.....
http://powersports.honda.com/2017/cb500f.aspx
Re: Mirrors
Posted: Wed Sep 06, 2017 5:26 pm
by homie
Re: Mirrors
Posted: Wed Sep 06, 2017 6:25 pm
by TheMaverick
I struggled with this too at first - in the end I finally got them in a position where they're covering the areas I need behind reasonably well and I've got my shoulders down to showing in slightly less than 1/2 of each mirror - helps if I tuck my elbows in a little (and this is when riding with a puffer jacket). Trick for me was not trying to get both converging on a single spot behind; they're close, but I move my head slightly to be able to get the complete picture of what's behind.
I thought of getting mirrors that stick out a bit more too - but now I've got them adjusted "just so" I made the decision to stick with stock - they're "adequate" for me - not great - not even "good" but adequate.
Re: Mirrors
Posted: Wed Sep 06, 2017 6:57 pm
by PCX150Rider
I may have mentioned this before on another thread but I can see what is directly behind me better from my right mirror (facing forward) and what's about to pass me or coming up along side better from my left mirror. If I got a tall windscreen I'd probably use the mirror extenders that come with it to widen the view. I guess you can also buy mirror extenders on ebay for about $20 a pair plus if you are in the U.K.. The OEM mirrors are 10mm right?
http://www.ebay.com/itm/Motorcycle-Mirr ... 1183470856
Or in the U.S. from J&P Cycles.
http://www.jpcycles.com/product/742-927 ... gJxrPD_BwE
Re: Mirrors
Posted: Wed Sep 06, 2017 7:24 pm
I bought the Givi mirror extenders for both of our bikes. Now I can't imagine not having them. I can actually see on both sides when I ride. No shoulders. No body. Just traffic. Get some mirror extenders.
Re: Mirrors
Posted: Wed Sep 06, 2017 7:51 pm
I don't know if this particular site would sell you the extenders only. I bought mine as a set.
http://www.motorcycleplanet.co.uk/produ ... x-125-150/
Re: Mirrors
Posted: Thu Sep 07, 2017 5:40 am
by fish
The CB500X mirrors work a treat on my Forza.
Plug and play.....even look like originals....just longer stems.
I posted this fix 3 yrs ago.
(Discovered this one day when looking at my son's CB500X. Beats the heck out of the goofy looking/cheap extenders)
Re: Mirrors
Posted: Thu Sep 07, 2017 5:55 am
by The Poacher
I tried the mirror extenders but it was as if the bolt was to long, it would tighten but the extender was still loose
Re: Mirrors
Posted: Thu Sep 07, 2017 9:01 am
fish wrote:The CB500X mirrors work a treat on my Forza.
Ta. Right I'm getting some.
Re: Mirrors
Posted: Thu Sep 07, 2017 9:41 am
by The Poacher
Me too!!
Re: Mirrors
Posted: Thu Sep 07, 2017 9:49 am
If you tightened the bolts and it is still loose, use some washers. I had no problem installing my extenders. If the extenders seem to loosen as you ride, get some loctite blue.
Re: Mirrors
Posted: Thu Sep 07, 2017 10:26 am
Me too!!
I got slightly distracted and bought some R&G extenders. Don't know why :roll:
Re: Mirrors
Posted: Fri Sep 08, 2017 5:48 pm
by springer1
Me too!!
I ordered a set of CB500X mirrors a few days ago based on some comments from the Forum archives. Got them from a salvager who sells on eb*y ...... should arrive any day now.
Re: Mirrors
Posted: Fri Sep 08, 2017 6:32 pm
Let me know how it goes and post some pictures. Ill do the same
Re: Mirrors
Posted: Mon Sep 11, 2017 5:21 am
Look OK. Look a bit awkward in the photo but are unobtrusive in real life. I tried them with and without the lower gaiter and preferred with.
When it stops raining :roll: I'll see if the vision is any better.
