It is currently Thu Feb 22, 2018 11:10 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3
Author Message
PostPosted: Thu Nov 16, 2017 9:54 pm
Offline
Year: 13PCX,15Forza
Color: Both Red
On the PCX I did end up removing the grab rail. Once that was off, catching the license plate wire was easy and neat. Look a bit before you drill the hole - I went just under the light, but should have drilled a couple of mm higher to make the run a bit easier. There are some plastic ridges under the fender that can be worked around if you notice they are there before you merrily start drilling.
Forza was easier. Didn't have to remove much of anything except a plastic liner under the fender. Drilled the hole, fed the wire behind, then threaded it into the license plate light housing. The connections supplied with the vololight is excellent and easy to use.
_________________
Please add yourself to the map: https://www.google.com/maps/d/edit?mid=1NlP7xk7KMdJReQnm-iDhldFBdpQ&ll=4.995760578398276%2C0&z=2
Top
 Profile
PostPosted: Fri Nov 17, 2017 11:03 am
Offline
Year: 2013/2016
Color: Black/Red
Thanks for the quick reply! Much appreciated.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
