It is currently Sun Feb 25, 2018 2:32 pm
Post new topic Reply to topic  [ 9 posts ]
Author Message
PostPosted: Mon Feb 12, 2018 3:56 pm
Offline
hi people I'm new here,
i have a 2016 pcx 125 it just stopped running yesterday as i was riding along. i got it taken home and have had a look today. its got a spark and the fuel pump primes but then the spark goes and the fuel stops pumping.
i have removed the fuel pump and that runs and works. now when I'm cranking the engine i have no earth to the fuel pump the power side is fine, checked all the fuses and easy things.
does this bike have a crank shaft sensor? thanks kevin
Top
 Profile
PostPosted: Mon Feb 12, 2018 4:52 pm
Offline
That is a pain. You say checked easy things, have you checked the battery. My thoughts were battery or alternator. Hoping it is the battery or something else simple
Top
 Profile
PostPosted: Mon Feb 12, 2018 5:52 pm
Offline
Year: Forza 300
Color: red/2014
Like other FI Hondas, it should have a Crank Position Sensor (Forza's is 110 ohms, 1.6 Vac @ cranking
speed, easy to check with a multitester). They're all +/- built the same, so should have similar specs.
With this sensor defective, there's no spark, no fuel injection (yet it may work for a few seconds
before giving up). Initial pump action is pre-programmed in the ECU and lasts about 2 secs. You'd
need a wiring diagram to see clear through this, but it's fairly easy to locate the sensor's wiring
and test it.
Top
 Profile
PostPosted: Mon Feb 12, 2018 8:36 pm
Offline
Year: Forza 300
Color: red/2014
UPDATE
If it has the Stop/Start system, its Crank Pos. Sensor is one complicated, multi-wire gimmick,
much more sophisticated in operation (just had a look at the corresponding diagram, available
online by googling 'pcx 125 wiring diagram'. Looks like this thing can't be tested without a
factory shop manual...
Does it show any fault code ?
Top
 Profile
PostPosted: Tue Feb 13, 2018 1:42 am
Offline
On the fault codes im getting one long blink then to fast ones after it. Yes i would say it has stop start. So is the prankshaft sensor apart of the start motor charging system system?
Top
 Profile
PostPosted: Tue Feb 13, 2018 2:00 am
Offline
Is there anyway i can do a diagnostics check on this bike where is the connector
Top
 Profile
PostPosted: Tue Feb 13, 2018 7:11 am
Offline
Year: Forza 300
Color: red/2014
Fault code #12 refers to INJECTOR, on both Hondas I own ( Giorno + Forza ).
- ECU can't diagnose a fuel pump problem.
- CKP problem may or may not have a code #, depending on year/model. If not, shop manual should
indicate resistance/Vac output specs.
You need a shop manual, or a competent dealer...
Top
 Profile
PostPosted: Tue Feb 13, 2018 11:11 am
Offline
Color: Pearl white
Hi,
According to the workshop manual you're having a fuel injector circuit malfunction, for troubleshooting send me a PM ;)
Top
 Profile
PostPosted: Tue Feb 13, 2018 1:15 pm
Offline
Howdy kevgam, welcome aboard! :) Glad our mechanical tooling members have come along to help you get things sorted. I'd also try to get my hands on a shop manual - they are invaluable - best tool in the house!
_________________
<<< LOCATION! Year & Color Please enter Yours today!
To enter your location and other: Log in. Click the User Control Panel button (top right of this page). Upon arrival, click Profile in left column. See the questions? Please Complete. Tis Simple. We Thank You Much (o;
"Miles From Nowhere, I Guess I'll Take My Time - to Reach There" Cat Stevens
Ride On, Ride On, Ride....On!
Top
 Profile
Who is online
Search for:
Jump to:
