Tire Inflator Blew My 5A Fuse
Year: 18 300 xmax
Re: Tire Inflator Blew My 5A Fuse
Keep The whole thing outside the bikes circuits, just get a cordless rechargeable… I have filled both my tires and still have power left, and I’ve done my car tires once and still had power left… It also automatically shuts off at the desired air pressure so there’s no filling, then checking , then filling, then checking, you just hook it up and go.
https://www.amazon.com/gp/product/B019F ... UTF8&psc=1
WI_Hedgehog
Powered by angry squirrels
Color: PearlDrkAshBlue
Post by WI_Hedgehog »
I bought an SAE plug off eBay, having 10gauge wire with the better insulation, crimped on a fuse and terminals and put longer battery screws in. It's mainly for the battery maintainer, but will power a heated suit, air pump, etc. When the battery maintainer is plugged in I fold up the microfiber cloth stored under the seat and put it between the seat latch and the latch mechanism to keep the seat gasket from putting pressure on the wire coming out of the storage area, which could dent the gasket and ruin the seal.
pcx888
Color: pearl white
Post by pcx888 »
pcx888 wrote:I have a option I use a device called Dynaplug.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
springer1
Year: 2018
Post by springer1 »
Woohhhaaa - I like that ...... Much better for sealing the hole than the traditional reamer/plug tool I have !!
https://www.youtube.com/watch?v=uQ2xFfXTE4g
Thanks !!
pcx888
Color: pearl white
Post by pcx888 »
I have the portable pump too. Works awesome. Saved me on several occasions.
dynaplug pump
dynaplug pump
2011 White PCX
Jge64 wrote:Keep The whole thing outside the bikes circuits, just get a cordless rechargeable… I have filled both my tires and still have power left, and I’ve done my car tires once and still had power left… It also automatically shuts off at the desired air pressure so there’s no filling, then checking , then filling, then checking, you just hook it up and go.
I’ve got this too. It’s perfect.
pcx888
Color: pearl white
Post by pcx888 »
I ran my wire of the Battery tender to the glove box. Drilled a small hole and pulled the cable thru. So clean it also charges my cell phone and bluetooth head set.
battery tender
battery tender
2011 White PCX
JohnL
Ozzie Old Fart
Ozzie Old Fart
Color: Dark Red
Post by JohnL »
Quick question, how easy is it to fit the pump to the tyre valve? Reason for asking, i have a 240v mini compressor and the (so called) easy fit adaptor is almost impossible to fit to the valve. It takes minutes to top up the pressure due to leakage around the valve connector.
I'm getting old and time is precious :D :D
pcx888
Color: pearl white
Post by pcx888 »
The system I use is Dynaplug comes with a hose and Micro pump.
dynaplug
dynaplug
2011 White PCX
Year: 18 300 xmax
Use a one way L valve....I use this one, only when filling, you just need one:
https://www.amazon.com/Topeak-Pressure- ... 8K6XA4NAC7
Gil
Post by Gil »
That's a nice kit PCX888. Here is the result of my quick 3D model and print from a couple months back. It could be much better, buy I'm not going to bother.
Gil
pcx888
Color: pearl white
Post by pcx888 »
Gil wrote:That's a nice kit PCX888. Here is the result of my quick 3D model and print from a couple months back. It could be much better, buy I'm not going to bother.
Gil
Nice setup too.
2011 White PCX
Works perfectly.
