The Honda PCX / Honda Forza Forums
Your predominant source of information for the Honda PCX 125, Honda PCX ESP, Honda PCX 150, and Forza 300. Now featuring a Forza 125 subforum!
It is currently Mon Oct 16, 2017 4:54 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: Ah oh...
PostPosted: Sat Aug 12, 2017 12:21 pm
Offline
We have the bikes on our carport, just in case we get a clear day that isn't going to rain on us. It is a bit of a tight squeeze getting by sometimes so we have to look where we step. As my wife walked behind me she looked down and fluid had started to run down the back tire...odd. she called me over and I checked it. Antifreeze, I popped the seat lock and check the fluid reservoir. Empty. How in the world can that happen?? It has just been sitting there for the last 5 days. Looks like I will have to take it to the basement and take it apart. Will driving it around to the side of the house hurt the engine?
_________________
Two Red 2013 Honda PCX150s
Lots and lots of extra lights
Custom seats from Thailand
Bad boy Airhorn on each
Top
 Profile
 Post subject: Re: Ah oh...
PostPosted: Sat Aug 12, 2017 12:24 pm
Offline
Year: 2015 PCX
30 secs of engine time? You'll be fine, I would think....I would do it, I'm assuming you don't want to push it.....
_________________
Glen in Fort Lauderdale
My build thread here:
http://www.hondapcx.org/viewtopic.php?f=2&t=4640
‘15 PCX
‘16 CTX 700 DCT/ABS
Top
 Profile
PostPosted: Sat Aug 12, 2017 2:14 pm
Offline
Pushing isn't good on me. I am having my 7th back procedure on Monday morning, so I don't want to push my luck on my back either.
If I open the side gate and the basement door it would probably take me 30 to 50 seconds to ride it into the basement. The other choice was to set up some fans and hope I don't get eaten alive by mosquitos on the carport, or lose some of the screws while I work out there in 90° Temps with about that much humidity.
However, if running the engine for that long will kill the engine, I won't start it at all.
_________________
Top
 Profile
PostPosted: Sat Aug 12, 2017 2:49 pm
Offline
Well, I just took the bike to the basement! Yes! ...of course, I forgot that the back gate area has about 2 inches of mud that I had to get through, on an uphill slope. I guess my bike doesn't work well as a dirt bike. It kind of got stuck. I had one heck of a time getting it out, so the 30 second ride turned into a couple of minutes. Now I have to figure out how to clean off the mud while in the basement, but that can wait. At least it is in the basement where it needs to be. :-/
_________________
Top
 Profile
PostPosted: Sat Aug 12, 2017 3:13 pm
Offline
Year: 2015 PCX
On a dead cold bike, I would think it would be fine for "minutes", not "seconds", the oil will get you the lubrication immediately.
_________________
‘15 PCX
‘16 CTX 700 DCT/ABS
Top
 Profile
PostPosted: Sat Aug 12, 2017 8:04 pm
Offline
Mel - Newspapers or 13 or 30 gallon plastic garbage bags (cut in half linearly?) to put under the bike. . .although by the time I post this the mud is probably dry by now. Georgia red clay by any chance? Gnarly eh?
Hope your back is OK. Damn that bites.
I haven't pulled the panels off my PCX yet. . .still got about 3K miles to go before I do the first valve adjustment (IAW the UK SM). . .so I can't talk from experience about what the problem could be. On theory however I'm thinking a hose connection popped off that either deteriorated or wasn't properly fastened or a crack in the reservoir. Could even be a crack in the radiator some place also but I hope not. I just had to have a radiator replaced in my Honda Civic. It cracked where the hose connected up top. . .however there was corrosion working along the top seam as well. When I pull my panels I'll take a good look at how my PCX radiator is built.
Remember this recent thread Alx123 did? There's a couple of pics they may make you think about your strategy.
http://www.hondapcx.org/viewtopic.php?f=19&t=7826
Good luck at the Doctor's on Monday. 8)
Top
 Profile
PostPosted: Sat Aug 12, 2017 8:51 pm
Offline
Antifreeze leak by the rear wheel maybe just a crack in the reservoir. I think I remember someone else having that problem. I would check that first.
Top
 Profile
PostPosted: Sat Aug 12, 2017 9:02 pm
Offline
Year: SV650AL7
Color: The correct one
There have been a few reports of cracked coolant reservoirs.
To clean a bike in a basement (or anywhere else) use a waterless cleaner and microfibre cloths.
http://www.meguiars.co.uk/shop/ultimate ... here-768ml
_________________
Top
 Profile
PostPosted: Sat Aug 12, 2017 9:58 pm
Offline
Color: blk
Any spillage or puddles that accumulate can be a sweet treat that some animals are attracted to.Unfortunately,it is poisonous and will kill any dog or animal that licks and swallows it.Emphasize care in keeping animals out of your basement or where a dog or animal could be exposed to it.
Top
 Profile
PostPosted: Sun Aug 13, 2017 9:52 am
Offline
Year: 2013,2014
Color: red+redder
Mel,
I had a cracked reservoir on mine, don't know why it cracked, but it did right at the outlet tube. I tried several ways to fix it, including epoxy, but nothing worked, so I broke down and bought a new one. They cost like 29 cents. They're easy to change out, but you have to remove some tupperware to get to it. Your system is probably still full of coolant if it's just a cracked reservoir, so don't worry about riding it around the house.
EZ fix.
Johnny
_________________
Top
 Profile
PostPosted: Sun Aug 13, 2017 10:48 am
Offline
Thanks for sticking up for our furry friends! ;)
Propylene Glycol is not only used in what is supposed to be "safe" anti-freeze" but also commonly known as an additive in food products.
Ethylene Glycol is the "evil one". It's the toxic and more traditional ingredient of "anti-freeze" which is still around.
The thing is that one may not be able to know what the content of their vehicle radiator is for sure unless it has a traceable history of maintenance right from the factory. So hope for the best and brace for the worst.
I wish the coolant level was a little easier to read on the PCX. Since mine is new and relatively clean it's hard to see the level. . .even using a flashlight. That being said I'll watch for leaks if there is a history of cracks developing in the reservoirs. :geek:
Top
 Profile
PostPosted: Sun Aug 13, 2017 12:41 pm
Offline
Color: blk
http://www.accessories-honda.com/images/OL999-9011.JPG
I believe Honda requires an ethylene glycol base as specified.. Not good for the furry fellows. Be careful of any leaks if using genuine Honda or similar specified product.
Top
 Profile
PostPosted: Wed Aug 16, 2017 1:31 pm
Offline
You are absolutely correct. Thanks for bringing that up!
I bought a quart of the Honda coolant the day I purchased the PCX (in a rush) and when I read the label details today on the back of the container it clearly stated that it was ethylene glycol. I knew I got the right stuff. . .just didn't check to see if it was ethylene or propylene. I always keep my cat inside the house so when I change the stuff out in the future he'll be OK. . .and I'll dispose of it so no birds or squirrels drink it either. ;)
Top
 Profile
PostPosted: Wed Aug 16, 2017 1:33 pm
Offline
Mel - what was the outcome of the coolant leak?
Hope the Doctor's visit went OK. 8)
Top
 Profile
PostPosted: Wed Aug 16, 2017 1:40 pm
Offline
Well, after being down for a few days after my back procedure I went to the basement and tore down the bike to see what the problem was. Guess what...cracked in the reservoir right where the line connects. Hmmm... ordered a new part and will just have to wait now.
_________________
Top
 Profile
PostPosted: Wed Aug 16, 2017 1:43 pm
Offline
Good mechani-CAN Mel! Ride the wife's if you get the itch :) ... bike I meant.
Top
 Profile
PostPosted: Wed Aug 16, 2017 2:34 pm
Offline
Great idea! It may be a little longer than I normally take when I want to ride, due to the Radio Frequency I had on my back on Monday, but I WILL ride...:-)
Now that the bike is partly apart I can do some other mods as well, when I am not riding. I like doing mods.
_________________
Top
 Profile
PostPosted: Wed Aug 16, 2017 2:44 pm
Offline
Color: blk
What frequency is your back on ? FM?? Right nip the channel selector and left is the volume?? No kidding what are they doing to your back ???Procedure ?
Top
 Profile
PostPosted: Wed Aug 16, 2017 3:56 pm
Offline
What other mods?
_________________
Pontification intolerant
Top
 Profile
PostPosted: Sat Aug 19, 2017 3:01 pm
Offline
First all I have a question. Now that I have changed out the coolant reservoir do I put antifreeze in it or do I remove the radiator cap and start the bike like I would a car...it has been so long since I have had to handle antifreeze that I can't even remember how I added more to a car. Do I use the reservoir in either process?? I have time to learn since I have to go to the dealer to get some anyway.
Next, the Radio Frequency procedure. For those who have not had one, they essentially go in and fry the nerves. A bit painful so I opted for semi unconscious. I was fine for a few hours but oh when everything woke up! Pain! But it should help with the constant pain I had running down my left leg from too many surgeries.
Next, mods. I needed to adjust my extra spot lights. I also added 2 more little strobe lights and set up some Junction boxes inside of the storage compartment for all those wires that go directly to the battery now. I still have more lights to attach but I may wait on them. I love doing mods...
_________________
Top
 Profile
Who is online
Search for:
Jump to:
