Hazard light's indicators pcx
Posted: Sun Jul 30, 2017 4:14 pm
by Rooneydavid79
Hi everyone hope someone can help my pcx indicators hazard light's and main beam seem to be playing up and it's intermittent any help will be much appreciated I'm from Southport Merseyside and my pcx is 2015 model
Re: Hazard light's indicators pcx
Posted: Sun Jul 30, 2017 4:16 pm
Is it still under warranty?
Posted: Sun Jul 30, 2017 4:24 pm
by Rooneydavid79
Hi m8 no sadly it's ran out of warranty
Posted: Sun Jul 30, 2017 4:42 pm
by Rooneydavid79
Had my bike for nearly 12 month's now have had this problem b4 took it the garage he said he sorted the wires out beneath the screen was good for a while but same problem came back took it back the garage was good for another month problem came back again don't want to go back the same garage think he's messing me about. And I've seen lots of bad reviews on-line Fastline in Preston great Scooter by the way
Posted: Sun Jul 30, 2017 4:44 pm
Rooneydavid79 wrote:Had my bike for nearly 12 month's now have had this problem b4 took it the garage he said he sorted the wires out beneath the screen was good for a while but same problem came back took it back the garage was good for another month problem came back again don't want to go back the same garage think he's messing me about
What exactly is the playing up/problem?
Posted: Sun Jul 30, 2017 4:49 pm
by Rooneydavid79
Sometimes no power to the indicators same with hazard light's and sometimes when you put the Maine beam on the they sometimes are ok for a bit was putting my hazards on b4 and the light's went sending me around the bend lol appart from this it's a great little Scooter
Posted: Wed Aug 02, 2017 11:57 am
I'm struggling to help as I don't have hazards on mine. Someone will be along soon.
If it was me I'd start by cleaning the hazard light switch, especially if it's on the same handlebar mounting as the headlights.
I'd start by spraying a contact cleaner into the switch without disassembling. If that doesn't work it take it apart and clean it.
Have you done a visual search for any obvious chaffed or broken wires?
Anyone else??
Posted: Wed Aug 02, 2017 12:22 pm
I don't have hazard lights on mine but do the main headlights and hazard lights share the same fuse? If so you might try changing the fuse, in case there is some problem with the fuse or connection. Otherwise, you could check the connectors for each, especially the ones under the front tire area. They shouldn't be loose because of the type of connectors they are, but they may have some dirt or grit in them.
Posted: Fri Aug 04, 2017 12:48 pm
by Rooneydavid79
Thanks for the advice guy's I've checked the fuses there good now my indicators are not working I've booked it in the Honda dealers for a service and asked them to sort it but I'm not booked in till the 15 august I'll let you know what's update
Posted: Sun Aug 20, 2017 2:38 am
by Rooneydavid79
Rooneydavid79 wrote:Thanks for the advice guy's I've checked the fuses there good now my indicators are not working I've booked it in the Honda dealers for a service and asked them to sort it but I'm not booked in till the 15 august I'll let you know what's update
Honda sorted it for me was loose connection on a couple of wires back of screen thanks for all replys
