Tightening side mirrors
My PCX died in the middle of the road the other day. Battery. All good now BUT when I got a mate to come grab me in his van, we had to take the mirrors off to get it in. Now Im trying to put the mirrors back on but they are tightening in the wrong positions before beginning to loosen again from the bottom! Something so simple is beginning to make me go a little mental so Im putting it out there.... Is there a little trick to it??
Previously: TBG 303RS
Currently: Honda PCX 125
Re: Tightening side mirrors
yes, you need to lossen the top nut on each then put the wing mirrors in place and tighten up using the bottom nut then tighten the top nut when you have put them at the correct angle.
Hope this helps
Hope this helps
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
