Hi,
I a newcommer to this site, hope there is someone that can help. Recently smashed a side panel, I have got the replacement but cannot see how to remove the old panel, its starting to look like I need to remove all the panels! is this correct, has anyone got sight of a repair manual?
how to replace side panel on pcx125
Re: how to replace side panel on pcx125
- Year: 2013 PCX 150
The front or rear side panel?
I put a body panel section from my PCX 150 service manual on this forum once. It should be the same as for a 125. Here is the link. http://hondapcx.org/viewtopic.php?f=3&t=17&start=60
Thanks for your reply,Mel46 wrote:I put a body panel section from my PCX 150 service manual on this forum once. It should be the same as for a 125. Here is the link. http://hondapcx.org/viewtopic.php?f=3&t=17&start=60
I had managed to replace my front side panel now, but thanks for link , I'll down load it,
Its quiet a job, I had to remove most of the panels from front to back to do the job but managed it with no damage, so saved a lot on Honda labor charge !!!!
