Headlight Burned Out & Needs Replacement
One of my headlight bulbs burned out and I need to replace it. Do I need to remove any of the plastic to do so, or is it accessible without removing anything? As well, is the bulb holder a twist out unit or a straight pull out unit?
jkhawaii
Re: Headlight Burned Out & Needs Replacement
Post by jkhawaii »
I just checked on my 150. you just reach up from underneath above the front tire and you can reach the bulbs. Didn't take the bulbs out though, so, I dont know about how they come out. hopefully they are the twist in and, twist out type.
Thanks JK. I was able to feel around under there and replace them. I am going to post a topic in the 'How To' section.
AFAIK the PCX sold in Thailand has different headlamp bulbs.
