How to disable side stand safety switch?
Ole
Post by Ole »
Can anyone tell or show me how to disable the side stand safety switch? You know, the one that won't let you warm up your PCX on the side stand. I hate this.
It can't be that complicated or is it? Is it a matter of finding the correct wires and soldering them together to make the bike think the side stand is up?
Thanks guys
I just picked up a PCX last night
Re: How to disable side stand safety switch?
If you're looking for it, the side stand switch is located on the sidestand pivot.
You could detach the wires and see what happens, if it won't start try splicing them together.
Better still leave it as it is, don't warm it up on the stand, get sat on the thing ready to go with your helmet on then start it, then once its running put your gloves on.
The time it takes to put your gloves on is enough warm up time.
Shoe
Post by Shoe »
Ole wrote:Can anyone tell or show me how to disable the side stand safety switch? You know, the one that won't let you warm up your PCX on the side stand. I hate this.
Thanks guys
Enjoy your new toy. As for warm-ups, I have about 6 blocks before having to get on it. Seems enough to get the oil pumping. Not to sound like a broken record, but that HP4S Honda oil increased my mileage. I would assume it's for racing bikes? It can't hurt!
Just like at a fueling station, I use the center stand during cold months, if you're concerned with that.
Engines have come a long way since the 70's. now my Diesel is another story. With 10 quarts of oil and several gallons of glycol it might take 1/2 my commute just for the sucker to blow warm air through the vents. Thank God for heated seats!
Range Rover have that one sorted, you can set a timer and in the morning it will automatically warm the engine up before you even switch on.
dasshreddar
Year: forzaruckuspcx
Post by dasshreddar »
Thanks guys
It is easy, unplug or remove the switch and solder/jump/tie the 2 remaining wires together (preferably solder them) ;)
gn2 wrote:Range Rover have that one sorted, you can set a timer and in the morning it will automatically warm the engine up before you even switch on.
Is that for the 600 yard drive to the nursery?
Ole
Post by Ole »
gn2 wrote: Better still leave it as it is, don't warm it up on the stand, get sat on the thing ready to go with your helmet on then start it.
what's a helmet?
Ole
Post by Ole »
thanks I kinda figured it was easy but thought I should ask the masses first.
I will dig in to it in the morn
I solder everything on my bikes wire nuts are evil
what's a helmet?
Its an essential piece of safety equipment which some morons think they don't need.
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Post by GeorgeSK »
If you have nothing worth protecting, well, what the hell. Darwin will take care of it.
