PCX Ignition replacement
geoinjb
Post by geoinjb »
Any body know an easy way to get to the unit? A video or written shortcut without taking everything apart and learning as I go? Cant seem to find any that are specific to the PCX. Mine is a 2013 150 if that matters. Thanks for the help.
kiapolo1887
Re: PCX Ignition replacement
Post by kiapolo1887 »
Do you have a copy of the service manual? You should be able to work your way through it with the service manual.
There is a PDF version of the Service Manual for the 2011 model. I don't think there is much difference between that version and the one for the 2013 model, which I have a paper version of. If you have one, look at chapter 19. I think that is the ignition section. You will have to remove the panels first though. I think that is chapter 3. Good luck. I don't think there is an easy way to do what you want to do.
